> Rules > Polemos Rules > Can MdE be played with GDD bases?
TOPIC: Can MdE be played with GDD bases?
PM henryeedcoat
henryeedcoat
7th Oct 2025 04:22:23
As the title says, I wonder if anyone has tried to play MdE with GDD bases. How well do the rules translate? Is it viable or should I just stick to GDD?
Regards
Henry
8th Oct 2025 05:25:24
Yes, it works fine pretty much as written, I have played lots of games exactly like this; it changes a little of the logic but not in such a way that is particularly noticeable. You also get a bit more space to manoeuvre.. The alternative is to butt two bases together for the infantry and the cavalry, and count that as a single base. To stop figure count getting too high for the bigger games, you can make skirmisher bases as half of the infantry base.
PM henryeedcoat
henryeedcoat
8th Oct 2025 05:44:53
That bit of space is important to me, since I've only got a 3'x2' dining room table. I've considered 10-15 base games as my limit so the table doesn't get too cluttered.
Regards
Henry
9th Oct 2025 08:25:08
The only thing I might suggest then is using a BD (e.g. 30mm) as the basic unit of measurement rather than the BW (e.g. 60mm), or at least try it both ways to see how you feel (longer ranges and faster movement, or the opposite).
10th Oct 2025 08:49:22
Well that was all very CON FuS InG
