> Painting and Modelling > Painting Questions > Bases and paint
TOPIC: Bases and paint
PM HuubStegeman
Bases and paint
HuubStegeman
6th Aug 2018 01:04:38
Hi All,
I'm currently also working on a 2mm army project and I was hoping to use the 30x30 Baccus bases for that as well. Ideally I would like to first stick the miniatures onto a base and only then prime them. Will the mdf of these bases stand acryllic primer from a spray can (Vallejo), or will it warp? Can anyone tell me from experience?
Thnx
PM wpilon
Bases and paint
wpilon
7th Aug 2018 03:02:41
I paint them with rattle can enamel all the time with no ill effects, so I think acrylic would be no problem.
Bases and paint
7th Aug 2018 10:43:32
No they won't warp. I have produced 2mm Armies for the battle of Langensaltza 1866 between Prussia and Hanover. In fact I terrained the bases, immediately after gluing the blocks on, with Windsor and Newton modelling paste. I then did a mix of painting, wahing and dry brushing, plus painting the base edges, after the figures were completed with no warping of the mdf at all. Once you go beyond the likes of 100mm base width you may want to worry about warping.
PM HuubStegeman
Bases and paint
HuubStegeman
7th Aug 2018 11:08:23
Thanks guys, that's the answer I was looking for.
Bases and paint
8th Aug 2018 06:04:50
This is one of the great benefits of the forum. Thanks Peter.
