> Painting and Modelling > Painting Questions > Hoplites' shields
TOPIC: Hoplites' shields
Hoplites' shields
7th Nov 2023 03:21:34
Well I will start this one...
PM Talbot
Hoplites' shields
Talbot
17th Apr 2025 11:19:34
- How to use shield decals? I bought Baccus hoplites and decals, but I need tutorial !
..................Thanks!
  - Hi Baccus !
- I'm sorry if I bother you but I would like to point out that the forum function Start a New Thread, doesn't work for me. - Can you help me ? - Thanks! - Stefano
PM DuncanWB
Hoplites' shields
DuncanWB
19th Apr 2025 04:36:52
I have some to apply soon (when I've finally finished base-painting all the shields). It isn't something I've done in decades, and even then it was on Airfix vehicles!  Any tips gratefully appreciated.
Altera Restat
PM Mort53
Hoplites' shields
Mort53
19th Apr 2025 06:13:45
It's been a while but when I did some 15mm figures (after they had been varnished).
  1. Use warm water to let the decal come away from the backing paper (do each decal separately)
  2. wipe the place where you want to put the decal clean of any dust or finger print
  3. keep the decal in there long enough to losen it from the paper. This will vary from decal to decal but usually anywhere between 10-30 seconds.
  4. hold the paper with tweezers and gently nudge the decal in place with a brush or tooth pick
  5. gently press down and then outwards from the center to settle it (I use a small cotton bud)
Mort
there was a light at the end of the tunnel, and it was a flamethrower
PM DuncanWB
Hoplites' shields
DuncanWB
21st Apr 2025 11:27:46
Varnish first! I knew there was something I'd forgotten...  Cotton bud is also a good tip - thank you!
Altera Restat
Hoplites' shields
23rd Apr 2025 01:24:24
You forgot the cursing when it folds itself in half, or floats off into the water, or comes off with your cotton bud or infact sticks to anything but the figure!
PM hejstinf
This is good
hejstinf
2nd Mar 2026 01:15:48
Good to know!
__________________________
https://www.medipakiet.pl/blog/astenia-czyli-przewlekle-zmeczenie-ktore-nie-ustepuje/
PM mollinary
Hoplites' shields
mollinary
2nd Mar 2026 05:08:22
Gosh, the lengths we all go to for things you cannot see from a yard away!!!
Mollinary
Hoplites' shields
4th Mar 2026 05:29:08
Click here to see closer the hoplites shield hand painted!
Hoplites' shields
9th Mar 2026 05:57:51
I will see if I can get time to do a video.   It's not that hard to apply them once you get the right technique and system up and running.   Honest!
